Dell XPS 15 L521X SSD Replacement
Introduzione
Vai al passo 1The SSD replacement only requires the removal of one phillips head screw. This is a very simple replacement, but it doesnt end after replacing the SSD. You may need to reinstall windows onto your Dell XPS.
Cosa ti serve
Find and remove the two .3cm torx head screws using a T5 screwdriver.
Find and remove the six Phillips head .3cm screws using a Phillips #0 screwdriver.
Find the single .3cm phillips head screw holding the SSD in place.
Remove the screw holding the SSD in place.
