Salta al contenuto principale
Dell XPS 14Z L412Z LCD Screen Glass Replacement
Colton Niewolny
Colton Niewolny e 4 altri collaboratori
Ultimo aggiornamento il June 19, 2018
30 - 45 minuti
Molto difficile
Introduzione
Vai al passo 1
The glass layer is important to clarity and protection of the LCD screen. However, accidents can cause the screen to crack which harms the viewing experience. This replacement is extremely difficult and requires attentive care and knowing your way around the tools. The tools required are the plastic opening tool, heat gun, and a Phillips #0 screwdriver.
Cosa ti serve
Strumenti
Mostra di più…
  1. Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: passo 1, immagine 1 di 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement, LCD Screen Glass: passo 1, immagine 2 di 2
    • Using the iFixit opening tools, carefully pry up the trim around the screen.
    • It is recommended to start in a corner.
  2. Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 2, immagine 1 di 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 2, immagine 2 di 2
    • Using a heat gun, carefully apply heat evenly across the glass.
  3. Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 3, immagine 1 di 2 Dell XPS 14Z L412Z LCD Screen Glass Replacement: passo 3, immagine 2 di 2
    • Using the iFixit opening tools, carefully pry the glass off the screen.
    • This is glass and will shatter if too much force is used.
Conclusione
UW Stout, Team S8-G3, Ogden Spring 2018 Membro di UW Stout, Team S8-G3, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G3
4 Membri
6 Guide realizzate
Un commento
to remove the black cover, use the rod of a pen pen cap. Spread both sides while pressing the top of the black cover (towards the inside of the screen). Must a little force.The closure mechanism is composed of two things that alternate every 2 cm: 1 clips that is sinking on the gray part (you have to lift the black part towards the right to take it out) then 1 rod that comes down in underneath (just stand aside - neither lift nor lower to remove)
wiwi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,202
