Salta al contenuto principale
Dell Precision 5510 Keyboard Replacement
Colin Hunter
Colin Hunter e 3 altri collaboratori
Ultimo aggiornamento il March 8, 2023
25 minuti
Moderato
Guida fornita dalla comunità
Necessarie Immagini Migliori
Inconveniente Markup
Introduzione Migliore
Introduzione
Vai al passo 1
If the keyboard is broken, missing, or malfunctioning you can replace the keyboard of the Dell Precision 5510 in 5 steps by following this guide.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Dell Precision 5510 Keyboard Replacement, Base Cover: passo 1, immagine 1 di 1
    • Open the system badge flap over to reveal the screws underneath (marked 1 on the image).
    • Remove the 12 screws that secure the base cover to the computer.
    According to the owner’s manual at https://www.dell.com/support/manuals/en-..., most of the screws for the base cover are Torx #5 with a couple of Phillips #0 under the badge flap.
    KCMax - Replica
  2. Dell Precision 5510 Keyboard Replacement: passo 2, immagine 1 di 1
    • Pry the edges base cover and lift it to remove it from computer.
  3. Dell Precision 5510 Keyboard Replacement, Fans: passo 3, immagine 1 di 2 Dell Precision 5510 Keyboard Replacement, Fans: passo 3, immagine 2 di 2
    • There are two screws on each fan circled in the images shown. Use a Phillips #0 screwdriver to remove all four screws.
    • Each fan has one 3.7mm screw and one 4.65mm screw.
  4. Dell Precision 5510 Keyboard Replacement: passo 4, immagine 1 di 2 Dell Precision 5510 Keyboard Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Each of the fans are plugged into the motherboard. Use tweezers to pull the plug out.
    • Do not grab by the wires, grab by the white rectangular region.
  5. Dell Precision 5510 Keyboard Replacement: passo 5, immagine 1 di 2 Dell Precision 5510 Keyboard Replacement: passo 5, immagine 2 di 2
    • Carefully extract the fan from its housing bed. It should remove easily if all parts have been disconnected.
  6. Dell Precision 5510 Keyboard Replacement, Battery: passo 6, immagine 1 di 2 Dell Precision 5510 Keyboard Replacement, Battery: passo 6, immagine 2 di 2
    • Unplug the connection that links the battery to the computer.
  7. Dell Precision 5510 Keyboard Replacement: passo 7, immagine 1 di 2 Dell Precision 5510 Keyboard Replacement: passo 7, immagine 2 di 2
    • Remove the four 4.0 mm JIS #0 screws surrounding the battery.
  8. Dell Precision 5510 Keyboard Replacement: passo 8, immagine 1 di 2 Dell Precision 5510 Keyboard Replacement: passo 8, immagine 2 di 2
    • Carefully remove the battery from the computer.
  9. Dell Precision 5510 Keyboard Replacement, Keyboard: passo 9, immagine 1 di 1
    • Remove 6 screws to take off the heat sink.
  10. Dell Precision 5510 Keyboard Replacement: passo 10, immagine 1 di 1
    • Remove all standalone motherboard screws.
    • 8 screws with lengths of either 3.7mm or 4.65mm
  11. Dell Precision 5510 Keyboard Replacement: passo 11, immagine 1 di 1
    • Remove the motherboard.
  12. Dell Precision 5510 Keyboard Replacement: passo 12, immagine 1 di 1
    • Remove nine screws from the back of the keyboard.
    • Screws are 1.9mm in length
  13. Dell Precision 5510 Keyboard Replacement: passo 13, immagine 1 di 1
    • Pull keyboard out and replace.
Conclusione
Colin Hunter
Membro da: 03/31/22
121 Reputazione
1 Guida realizzata
IUPUI, Team 2-1, Harley Spring 2022 Membro di IUPUI, Team 2-1, Harley Spring 2022
IUPUI-HARLEY-S22S2G1
4 Membri
4 Guide realizzate
1Commento della guida
Do you need to remove the heatsink? I don't see why it cant be left on.
Alexandru - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 47
Tutti i Tempi: 2,448
