Salta al contenuto principale
Dell Optiplex 330 SFF Power Supply Replacement
Oli
Oli e 4 altri collaboratori
Ultimo aggiornamento il May 28, 2023
10 - 15 minuti
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This shows you how to replace a blown power supply on a Dell Optiplex 330 small form factor PC. Power supplies are normally the first part to go on a desktop and will result in a solid amber power light illuminated on a Dell desktop.
Cosa ti serve
Strumenti
  1. Dell Optiplex 330 SFF Power Supply Replacement, Power Supply: passo 1, immagine 1 di 3 Dell Optiplex 330 SFF Power Supply Replacement, Power Supply: passo 1, immagine 2 di 3 Dell Optiplex 330 SFF Power Supply Replacement, Power Supply: passo 1, immagine 3 di 3
    • Before you start make sure that all of the leads have been disconnected from the computer.
    • It is strongly recommended that you leave the computer off for at least 15 minutes to allow the components to cool down.
    • You should also ground yourself before starting by using an anti-static band or touching a metal object connected to the ground. This prevents static build up which can destroy sensitive components.
  2. Dell Optiplex 330 SFF Power Supply Replacement: passo 2, immagine 1 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 2, immagine 2 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 2, immagine 3 di 3
    • Round the back of the computer next to the power supply you will find a latch.
    • In order to release the case pull this latch straight back - this should make the back of the case pop up.
    • You can now just lift the case up and away from the computer.
  3. Dell Optiplex 330 SFF Power Supply Replacement: passo 3, immagine 1 di 2 Dell Optiplex 330 SFF Power Supply Replacement: passo 3, immagine 2 di 2
    • Before you can remove the power supply you first have to remove the optical drive.
    • First find the two cables going into the optical drive - they are shown in the first picture.
    • Gently pull both of them out - one of the cables might have a little latch that you have to press in order to release it from the optical drive.
  4. Dell Optiplex 330 SFF Power Supply Replacement: passo 4, immagine 1 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 4, immagine 2 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 4, immagine 3 di 3
    • To remove the optical drive first find the little blue latch located next to the optical drive.
    • Pull the latch straight up - at the same time pull the optical drive back. It should now be easy to remove it from the computer.
  5. Dell Optiplex 330 SFF Power Supply Replacement: passo 5, immagine 1 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 5, immagine 2 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 5, immagine 3 di 3
    • It should now look like the first picture with the optical drive removed.
    • You now need to remove the power cable from the hard drive.
    • Gently pull the cable out of the back of the hard drive.
  6. Dell Optiplex 330 SFF Power Supply Replacement: passo 6, immagine 1 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 6, immagine 2 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 6, immagine 3 di 3
    • You now need to remove the power cable connected to the motherboard.
    • Locate the large 24 pin power connecter - it is located next to the power supply. Carefully press down on the little latch and pull straight up to release.
    • Repeat this procedure for the little 4 pin connecter located between the processer and hard drive.
  7. Dell Optiplex 330 SFF Power Supply Replacement: passo 7, immagine 1 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 7, immagine 2 di 3 Dell Optiplex 330 SFF Power Supply Replacement: passo 7, immagine 3 di 3
    • In order to remove the power supply you have to first remove two screws connecting the power supply to the case.
    • You can now slide the power supply straight back and lift it straight up and out of the computer.
    • It should look like the last picture after the power supply is removed.
Conclusione
Altre 15 persone hanno completato questa guida.
Oli
Membro da: 01/03/14
1.442 Reputazione
4 Guide realizzate
3 Commenti
Would this be the first item to go bad if the computer is simply not powering on?
Edgar - Replica
If nothing at all was happening when the computer was switched on then certainly its highly likely that the power supply is bad although it could also be a faulty motherboard.
Oli - Replica
Power supply ko repair kese kare
Rahul tak - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 55
Tutti i Tempi: 10,124
