Salta al contenuto principale
Dell Latitude E7270 Battery Replacement
Jacob Clement
Jacob Clement e 4 altri collaboratori
Ultimo aggiornamento il August 12, 2024
10 minuti
Moderato
Guida In Evidenza
Introduzione
Vai al passo 1
Use this guide to replace a broken battery on your Dell Latitude E7270 or to safely remove and replace other components without causing further damage.
The battery is the power bank that gives power to each component in the computer. After time they become inefficient or incapable of holding a charge at all. A bad battery can also get extremely hot under normal use. This can cause your computer to shut off without warning.
Before using this guide, check out the troubleshooting page to see if your symptoms match any that represent a bad battery.
You can also use this guide to upgrade the battery instead of using the original battery.
This replacement requires a #00 Phillips head screwdriver.
NOTE: This guide requires removal of the back panel and includes the extra prerequisite guide steps.
Cosa ti serve
Strumenti
  1. Dell Latitude E7270 Battery Replacement, Back Panel: passo 1, immagine 1 di 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Battery Replacement: passo 2, immagine 1 di 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Battery Replacement: passo 3, immagine 1 di 1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Battery Replacement: passo 5, immagine 1 di 2 Dell Latitude E7270 Battery Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
On Step 4 there is no screw on middle since that hole is for backpanel center screw.
Mikko Kuusio - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 44
Tutti i Tempi: 3,773
