Salta al contenuto principale
Dell Latitude E6420 Backplate Replacement
Madysen Eames
Madysen Eames e un altro collaboratore
Ultimo aggiornamento il May 23, 2018
10 minuti
Facile
Introduzione
Vai al passo 1
The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
Cosa ti serve
Strumenti
Mostra di più…
  1. Dell Latitude E6420 Backplate Replacement, Battery: passo 1, immagine 1 di 2 Dell Latitude E6420 Backplate Replacement, Battery: passo 1, immagine 2 di 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Backplate Replacement: passo 2, immagine 1 di 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: passo 3, immagine 1 di 2 Dell Latitude E6420 Backplate Replacement, CD/DVD Drive: passo 3, immagine 2 di 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Backplate Replacement: passo 4, immagine 1 di 2 Dell Latitude E6420 Backplate Replacement: passo 4, immagine 2 di 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Backplate Replacement, Backplate: passo 5, immagine 1 di 2 Dell Latitude E6420 Backplate Replacement, Backplate: passo 5, immagine 2 di 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Backplate Replacement: passo 6, immagine 1 di 2 Dell Latitude E6420 Backplate Replacement: passo 6, immagine 2 di 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
Conclusione
Altre 4 persone hanno completato questa guida.
Madysen Eames
Membro da: 02/27/18
1.555 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 22
Ultimi 30 Giorni: 31
Tutti i Tempi: 2,042
