Salta al contenuto principale
Dell Inspiron 3501 Battery Replacement
Cosa ti serve
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: passo 1, immagine 1 di 2 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: passo 2, immagine 1 di 2 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: passo 2, immagine 2 di 2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: passo 3, immagine 1 di 2 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: passo 3, immagine 2 di 2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: passo 4, immagine 1 di 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: passo 4, immagine 2 di 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: passo 5, immagine 1 di 2 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: passo 5, immagine 2 di 2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: passo 6, immagine 1 di 2 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: passo 6, immagine 2 di 2
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: passo 7, immagine 1 di 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: passo 7, immagine 2 di 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: passo 7, immagine 3 di 3
    • Lift the battery straight out of its recess and remove it.
Conclusione
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
Membro da: 01/16/22
127.722 Reputazione
592 Guide realizzate
iFixit Membro di iFixit
Staff
141 Membri
17.895 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 89
Tutti i Tempi: 1,377
