Salta al contenuto principale
Dell Inspiron 15-3543 RAM Replacement
Brianna Blackburn
Brianna Blackburn e un altro collaboratore
Ultimo aggiornamento il June 4, 2018
3 minuti
Facile
Introduzione
Vai al passo 1
Is the RAM in your Dell Inspiron 15-3543 defective or full? If so, here is the guide to fix the problem by simply replacing your RAM. All you need is the standard #0 Phillips Screwdriver head in order to remove the one screw involved with this replacement.
Cosa ti serve
Strumenti
  1. Dell Inspiron 15-3543 RAM Replacement, RAM: passo 1, immagine 1 di 2 Dell Inspiron 15-3543 RAM Replacement, RAM: passo 1, immagine 2 di 2
    • Using a #0 Phillips screwdriver, remove the 2.0mm screw from the back of the device beside the vents.
  2. Dell Inspiron 15-3543 RAM Replacement: passo 2, immagine 1 di 3 Dell Inspiron 15-3543 RAM Replacement: passo 2, immagine 2 di 3 Dell Inspiron 15-3543 RAM Replacement: passo 2, immagine 3 di 3
    • Slide the panel off by placing your hands on top and, while using a little force, sliding your hands down.
  3. Dell Inspiron 15-3543 RAM Replacement: passo 3, immagine 1 di 3 Dell Inspiron 15-3543 RAM Replacement: passo 3, immagine 2 di 3 Dell Inspiron 15-3543 RAM Replacement: passo 3, immagine 3 di 3
    • Using two fingers, slide the two notches holding the RAM in place outwards.
    • After the notches are moved outwards, the RAM will pop up and it can be pulled out.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,030
