Salta al contenuto principale
Dell Inspiron 15-3543 Keyboard Replacement
Brianna Blackburn
Brianna Blackburn e 2 altri collaboratori
Ultimo aggiornamento il May 30, 2023
7 minuti
Moderato
Introduzione
Vai al passo 1
Have all of the keys or some keys on the keyboard for your Dell Inspiron 15-3543 stopped working? If so, here is the guide to fix the problem by simply replacing your keyboard. All you need is the metal spudger tool in order to pry the keyboard up and remove the cable ribbon.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Dell Inspiron 15-3543 Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Turn the device over and open it.
    • You will see 5 notches at the top of the keyboard.
    • Stick the end of the metal spudger between each of these notches to pry the keyboard up. Once you hear a pop sound, stop and move onto the next notch.
  2. Dell Inspiron 15-3543 Keyboard Replacement: passo 2, immagine 1 di 2 Dell Inspiron 15-3543 Keyboard Replacement: passo 2, immagine 2 di 2
    • Once all five notches at the top of the keyboard are loosened, begin pulling it up from the top.
    • Pull the keyboard up slowly so you don't tear the ribbon cable out or damage it.
  3. Dell Inspiron 15-3543 Keyboard Replacement: passo 3, immagine 1 di 2 Dell Inspiron 15-3543 Keyboard Replacement: passo 3, immagine 2 di 2
    • To remove the ribbon cable, use the metal spudger tool to pop the ribbon cable lock up.
    • After popping up the ribbon cable lock, you can pull the ribbon cable out.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Thanks. Could you please suggest a recommended replacement keyboard? I didn't find any branded replacement item in Amazon.
Arun Prasad - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 32
Tutti i Tempi: 1,194
