Salta al contenuto principale
Dell Inspiron 15 Optical Drive Replacement
Edward Pacheco
Edward Pacheco e un altro collaboratore
Ultimo aggiornamento il May 17, 2016
10 - 15 minuti
Facile
Introduzione Migliore
Cosa ti serve
Strumenti
  1. Dell Inspiron 15 Optical Drive Replacement, Battery: passo 1, immagine 1 di 2 Dell Inspiron 15 Optical Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your laptop is powered off completely and is not connected to the charger.
    • Close the laptop and place it so that the back of the screen is lying flat on your work surface.
    • Slide both of the battery-release latches towards the outer edges of the laptop to unlock the battery flap.
  2. Dell Inspiron 15 Optical Drive Replacement: passo 2, immagine 1 di 1
    • Lift the battery at an angle using your fingertips and remove it from the laptop.
    • Press and hold the power button for 5 seconds. This ensures that any remaining power will drain out of the computer.
  3. Dell Inspiron 15 Optical Drive Replacement, Optical Drive: passo 3, immagine 1 di 2 Dell Inspiron 15 Optical Drive Replacement, Optical Drive: passo 3, immagine 2 di 2
    • Remove the 5mm long Phillips #0 screw that is holding the optical drive in place, as pictured.
    • You can now slide the optical disk drive out of the computer.
    • You do not have to remove the base cover or the Hard Drive if you want to remove just the optical drive.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 27
Tutti i Tempi: 4,844
