Dell Inspiron 15 Memory Module Replacement
Introduzione
Vai al passo 1In this guide, we will be showing you how to remove and replace the Memory Module.
Using your fingertips, spread apart the securing clips at each end of the memory-module slot until the memory module pops up.
Slide and remove the memory module from the memory-module slot.
Align the notch on the NEW memory module with the tab on the memory-module slot.
