Dell Inspiron 15 5578 2-in-1 Memory Module Replacement
2 - 5 minuti
Molto facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1In this guide, we will be showing you how to remove and replace the Memory Module.
Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
Align the notch on the memory module with the tab on the memory-module slot.
Slide the memory module firmly into the slot at an angle and press the memory module down until it clicks into place.
Quasi finito!
Linea Traguardo
