Salta al contenuto principale
Dell Inspiron 15 5577 Gaming Memory Modules Replacement
Terrence15
Terrence15 e 2 altri collaboratori
Ultimo aggiornamento il November 16, 2019
3 - 7 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
In this guide, we will be showing you how to remove and replace the Memory Modules.
  1. Dell Inspiron 15 5577 Gaming Memory Modules Replacement, Popping up the Memory Module: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Use your fingertips to carefully spread apart the securing-clips on each end of the memory-module slot until the memory module pops up.
  2. Dell Inspiron 15 5577 Gaming Memory Modules Replacement, Remove the Memory Module: passo 2, immagine 1 di 1
    • Remove the memory module from the memory-module slot.
    • Align the notch on the NEW memory module with the tab on the memory-module slot and slide it firmly into the slot at an angle.
  3. Dell Inspiron 15 5577 Gaming Memory Modules Replacement, Press the Memory Module Down: passo 4, immagine 1 di 1
    • Press the memory module down until it clicks into place.
    • NOTE: If you do not hear the click, remove the memory module and reinstall it
Linea Traguardo
Terrence15
Membro da: 12/18/17
79.585 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,075
