Salta al contenuto principale
Dell Inspiron 14-7437 Speaker Replacement
Katelyn Remy
Katelyn Remy e 3 altri collaboratori
Ultimo aggiornamento il August 8, 2019
6 minuti
Facile
Introduzione
Vai al passo 1
if the speaker is not playing sounds properly or liquid is spilled into the speaker gap in the frame of your laptop it is easy and simple to replace them.
Cosa ti serve
Strumenti
Mostra di più…
  1. Dell Inspiron 14-7437 Speaker Replacement, Base Cover: passo 1, immagine 1 di 2 Dell Inspiron 14-7437 Speaker Replacement, Base Cover: passo 1, immagine 2 di 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Speaker Replacement: passo 2, immagine 1 di 2 Dell Inspiron 14-7437 Speaker Replacement: passo 2, immagine 2 di 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Speaker Replacement, Battery: passo 3, immagine 1 di 2 Dell Inspiron 14-7437 Speaker Replacement, Battery: passo 3, immagine 2 di 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Speaker Replacement: passo 4, immagine 1 di 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Speaker Replacement: passo 5, immagine 1 di 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Speaker Replacement, Speaker: passo 6, immagine 1 di 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Speaker Replacement: passo 7, immagine 1 di 3 Dell Inspiron 14-7437 Speaker Replacement: passo 7, immagine 2 di 3 Dell Inspiron 14-7437 Speaker Replacement: passo 7, immagine 3 di 3
    • Remove the speakers from the case.
Conclusione
Katelyn Remy
Membro da: 03/10/16
449 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 24
Tutti i Tempi: 1,128
