Salta al contenuto principale
Dell Inspiron 13z 5323 Memory Module Replacement
Terrence15
Terrence15 e 2 altri collaboratori
Ultimo aggiornamento il November 14, 2019
50 secondi - 4 minuti
Facile
Prerequisite Mancanti
Guida fornita dalla comunità
Introduzione
Vai al passo 1
In this guide, we will show you how to remove and replace the Memory Module.
  1. Dell Inspiron 13z 5323 Memory Module Replacement, Popping up the Memory Module: passo 1, immagine 1 di 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin".
    • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory-module securing clips.
    • Close the display and turn the computer over.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
  2. Dell Inspiron 13z 5323 Memory Module Replacement, Removing the Memory Module: passo 2, immagine 1 di 2 Dell Inspiron 13z 5323 Memory Module Replacement, Removing the Memory Module: passo 2, immagine 2 di 2
    • Remove the memory module from the memory-module connector.
  3. Dell Inspiron 13z 5323 Memory Module Replacement, Align the Notch: passo 3, immagine 1 di 2 Dell Inspiron 13z 5323 Memory Module Replacement, Align the Notch: passo 3, immagine 2 di 2
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the connector labeled "DIMM A" before you install a memory module in the connector labeled "DIMM B."
    • Align the notch on the memory module with the tab on the memory-module connector.
  4. Dell Inspiron 13z 5323 Memory Module Replacement, Installing the Memory Module: passo 4, immagine 1 di 1
    • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not in stalled properly, the computer may not boot.
Conclusione
Terrence15
Membro da: 12/18/17
79.585 Reputazione
441 Guide realizzate
RampUP America, Inc. Membro di RampUP America, Inc.
Community
43 Membri
1.985 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 153
