Salta al contenuto principale
Dell Inpiron 3542 Motherboard  Replacement
Rachel lindsey
Rachel lindsey e 8 altri collaboratori
Ultimo aggiornamento il January 10, 2025
45 minuti - 1 ora
Moderato
Necessarie Più Immagini
Fallo a Fettine
Introduzione
Vai al passo 1
If your Dell Inspiron 3542 laptop has stopped working or needs to be upgraded with a new motherboard, this guide will help you do so. The motherboard is responsible for system stability and performance, and your laptop will load a lot faster. If the motherboard stops working, then the entire system will begin to fail, including fans, lights, and more.
Before beginning, it is highly recommended to power off the laptop and disconnect the power supply before starting. This can prevent short circuits and other damages.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Dell Inpiron 3542 Motherboard  Replacement, Motherboard: passo 1, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement, Motherboard: passo 1, immagine 2 di 2
    • Slide the latches on both sides of the laptop outward to unlock the battery.
    • Remove the battery from the computer.
    • Replacing a motherboard can lead to data loss. Make sure to backup any important data on the laptop before replacing the motherboard.
  2. Dell Inpiron 3542 Motherboard  Replacement: passo 2, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement: passo 2, immagine 2 di 2
    • Remove the screw. (1 x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inpiron 3542 Motherboard  Replacement: passo 3, immagine 1 di 3 Dell Inpiron 3542 Motherboard  Replacement: passo 3, immagine 2 di 3 Dell Inpiron 3542 Motherboard  Replacement: passo 3, immagine 3 di 3
    • Move the hard drive to the open area and remove it.
  4. Dell Inpiron 3542 Motherboard  Replacement: passo 4, immagine 1 di 3 Dell Inpiron 3542 Motherboard  Replacement: passo 4, immagine 2 di 3 Dell Inpiron 3542 Motherboard  Replacement: passo 4, immagine 3 di 3
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the wireless card from the laptop.
  5. Dell Inpiron 3542 Motherboard  Replacement: passo 5, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement: passo 5, immagine 2 di 2
    • Remove all screws from the bottom of the laptop. (10 x M2.5 x 5mm)
    • Turn over the laptop and open it.
  6. Dell Inpiron 3542 Motherboard  Replacement: passo 6, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement: passo 6, immagine 2 di 2
    • Use the plastic prying device to release the keyboard. Avoid from using excessive force to prevent damages.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
  7. Dell Inpiron 3542 Motherboard  Replacement: passo 7, immagine 1 di 3 Dell Inpiron 3542 Motherboard  Replacement: passo 7, immagine 2 di 3 Dell Inpiron 3542 Motherboard  Replacement: passo 7, immagine 3 di 3
    • Unplug the touch pad cables located on the palm rest.
    • Remove the screws. (3 x M2.5 x 5mm)
  8. Dell Inpiron 3542 Motherboard  Replacement: passo 8, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement: passo 8, immagine 2 di 2
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  9. Dell Inpiron 3542 Motherboard  Replacement: passo 9, immagine 1 di 1
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  10. Dell Inpiron 3542 Motherboard  Replacement: passo 10, immagine 1 di 1
    • Loosen the cables on the antenna.
  11. Dell Inpiron 3542 Motherboard  Replacement: passo 11, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement: passo 11, immagine 2 di 2
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  12. Dell Inpiron 3542 Motherboard  Replacement: passo 12, immagine 1 di 1
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  13. Dell Inpiron 3542 Motherboard  Replacement: passo 13, immagine 1 di 2 Dell Inpiron 3542 Motherboard  Replacement: passo 13, immagine 2 di 2
    • Unplug the cable on the bottom part of the mother board.
    • Remove the cable on the right side of the motherboard. (3x M2.5 x 5mm)
    • Remove the motherboard from the laptop.
Conclusione
To reassemble your device, follow these instructions in reverse order. Congratulations on replacing the Motherboard on your Dell Inpiron 3542.
Altre 5 persone hanno completato questa guida.
Un commento
Anyone know where I can purchase a board for a Dell Inspiron 3542 in the UK?
Darrell Haslam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 29
Tutti i Tempi: 3,746
