Salta al contenuto principale
D-Link DCS-825L Back Casing Replacement
April Ulrich
April Ulrich e 4 altri collaboratori
Ultimo aggiornamento il May 7, 2024
5 minuti
Moderato
Introduzione
Vai al passo 1
Did the back casing of your Wi-Fi Baby Camera crack? The answer to fixing and replacing that is in this guide.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. D-Link DCS-825L Back Casing Replacement, Accent Ring: passo 1, immagine 1 di 1
    • Grasp the side of the accent ring. There is a notch that your thumb will be able to grab ahold of.
  2. D-Link DCS-825L Back Casing Replacement: passo 2, immagine 1 di 1
    • Twist the accent ring until it pops off. You may need to use both hands if the accent ring is stuck.
  3. D-Link DCS-825L Back Casing Replacement: passo 3, immagine 1 di 1
    • Replace your accent ring with whichever color you choose.
  4. D-Link DCS-825L Back Casing Replacement, Back Casing: passo 4, immagine 1 di 2 D-Link DCS-825L Back Casing Replacement, Back Casing: passo 4, immagine 2 di 2
    • Remove one Phillips #2 screw from each side of the camera lens.
  5. D-Link DCS-825L Back Casing Replacement: passo 5, immagine 1 di 3 D-Link DCS-825L Back Casing Replacement: passo 5, immagine 2 di 3 D-Link DCS-825L Back Casing Replacement: passo 5, immagine 3 di 3
    • Pull the Wi-Fi Baby Camera open.
    • It should be easily done after the screws are removed.
  6. D-Link DCS-825L Back Casing Replacement: passo 6, immagine 1 di 2 D-Link DCS-825L Back Casing Replacement: passo 6, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Take your tweezers and gently pull the white tip out from its plug that is connected to a red and black twisted wire.
  7. D-Link DCS-825L Back Casing Replacement: passo 7, immagine 1 di 3 D-Link DCS-825L Back Casing Replacement: passo 7, immagine 2 di 3 D-Link DCS-825L Back Casing Replacement: passo 7, immagine 3 di 3
    • Take your tweezers and gently pull the white tip that is on the end of the white wire (the antenna) out from its plug in.
Conclusione
April Ulrich
Membro da: 10/09/18
205 Reputazione
2 Guide realizzate
USF Tampa, Team S1-G5, Leahy Fall 2018 Membro di USF Tampa, Team S1-G5, Leahy Fall 2018
USFT-LEAHY-F18S1G5
4 Membri
4 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 22
Tutti i Tempi: 448
