Creative Zen Vision W LCD Screen Replacement
Introduzione
Vai al passo 1This guide will show you how to remove and install a new LCD screen in your device. Use this guide if your screen is broken or damaged and needs to be replaced.
Cosa ti serve
Remove the two screws (2.5 mm) on the top and bottom of the device using a Phillips #0 screwdriver.
Use a spudger to separate the metal tabs that hold the screen in place on the right side.
Preparati per le riparazioni future
Acquista tutti
