Salta al contenuto principale
Corsair Scimitar Mouse Wheel Replacement
Amelia Camp
Amelia Camp e 2 altri collaboratori
Ultimo aggiornamento il September 17, 2024
10 - 30 minuti
Moderato
Guida Studente in Evidenza
Introduzione
Vai al passo 1
This guide will show you how to replace the scroll wheel for a Corsair Scimitar. The scroll wheel is the small disk in the middle of the mouse that allows you to scroll up and down pages easily when you rotate it. You may need to replace the scroll wheel of your Corsair Scimitar if the scroll wheel resists being rotated, if the scroll wheel does not rotate at all, or if the scroll wheel rotates but doesn't respond to scrolling.
Replacement scroll wheels are sometimes difficult to find online to purchase. If you have a 3D printer available to you, 3D printing the scroll wheel is a viable alternative to purchasing one. For more on 3D printing a Corsair Scimitar scroll wheel, click here.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: passo 1, immagine 1 di 2 Corsair Scimitar Mouse Wheel Replacement, Corsair Scimitar Mouse Wheel: passo 1, immagine 2 di 2
    • Heat the mouse feet with a heat gun to loosen the adhesive.
    • Pry the mouse feet off of the mouse with the metal spudger.
  2. Corsair Scimitar Mouse Wheel Replacement: passo 2, immagine 1 di 2 Corsair Scimitar Mouse Wheel Replacement: passo 2, immagine 2 di 2
    • Unscrew the four 8.9 mm bottom screws with a JIS #00 screwdriver.
    • Loosen the keyslider lock with a 2.5 mm hex screw driver.
  3. Corsair Scimitar Mouse Wheel Replacement: passo 3, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 3, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 3, immagine 3 di 3
    • Pry along the seam of the mouse body to separate the top and bottom halves.
  4. Corsair Scimitar Mouse Wheel Replacement: passo 4, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 4, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 4, immagine 3 di 3
    • Remove the top cover from the mouse.
  5. Corsair Scimitar Mouse Wheel Replacement: passo 5, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 5, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 5, immagine 3 di 3
    • Lift the locking mechanism on the auxiliary switch board ribbon cable connector with a plastic spudger.
    • Pull the ribbon cable gently to disconnect from the main board.
  6. Corsair Scimitar Mouse Wheel Replacement: passo 6, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 6, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 6, immagine 3 di 3
    • Lift the locking mechanism on the Key Slider assembly ribbon cable connector with a plastic spudger.
    • Pull the Key Slider assembly ribbon cable gently to disconnect it from the main board.
  7. Corsair Scimitar Mouse Wheel Replacement: passo 7, immagine 1 di 2 Corsair Scimitar Mouse Wheel Replacement: passo 7, immagine 2 di 2
    • Pull the Keyslider ribbon cable up and out of the plastic post.
  8. Corsair Scimitar Mouse Wheel Replacement: passo 8, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 8, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 8, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the 6 mm screw from the key slider assembly.
    • Remove the key slider assembly from the body of the mouse.
  9. Corsair Scimitar Mouse Wheel Replacement: passo 9, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 9, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 9, immagine 3 di 3
    • Disconnect the data cable from the auxiliary switch board.
  10. Corsair Scimitar Mouse Wheel Replacement: passo 10, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 10, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 10, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the two 6 mm screws from the auxiliary switch board.
    • Remove the auxiliary switch board.
  11. Corsair Scimitar Mouse Wheel Replacement: passo 11, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 11, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 11, immagine 3 di 3
    • Use a JIS #0 screwdriver to remove the three 6 mm screws from the main board to separate it from the mouse body.
  12. Corsair Scimitar Mouse Wheel Replacement: passo 12, immagine 1 di 2 Corsair Scimitar Mouse Wheel Replacement: passo 12, immagine 2 di 2
    • Disconnect the data cable from the main board.
  13. Corsair Scimitar Mouse Wheel Replacement: passo 13, immagine 1 di 2 Corsair Scimitar Mouse Wheel Replacement: passo 13, immagine 2 di 2
    • Lift the main board off of the body of the mouse.
  14. Corsair Scimitar Mouse Wheel Replacement: passo 14, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 14, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 14, immagine 3 di 3
    • Push the scroll wheel gently away from the rotary encoder switch to remove it.
    • Check the rotary encoder hex hole to make sure it is clear of debris.
  15. Corsair Scimitar Mouse Wheel Replacement: passo 15, immagine 1 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 15, immagine 2 di 3 Corsair Scimitar Mouse Wheel Replacement: passo 15, immagine 3 di 3
    • Remove the rubber ring from the scroll wheel.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 278
Tutti i Tempi: 7,372
