Salta al contenuto principale
Core Assembly Removal
Cosa ti serve
    1. Core Assembly Removal, Power down your watch: passo 1, immagine 1 di 1
      • Before starting repairs, take your watch off the charger and power it down.
      • Remove the watch band.
      Chiedi a FixBot
      Aggiungi Commento
    2. Core Assembly Removal, Unscrew the back cover: passo 2, immagine 1 di 1
      • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
      Chiedi a FixBot
      Aggiungi Commento
    3. Core Assembly Removal, Pry open the back cover: passo 3, immagine 1 di 2 Core Assembly Removal, Pry open the back cover: passo 3, immagine 2 di 2
      • Insert an opening tool into the seam between the back cover and the metal housing.
      • Twist the opening tool to create a gap.
      • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    4. Core Assembly Removal, Disconnect the sensor flex cable: passo 4, immagine 1 di 2 Core Assembly Removal, Disconnect the sensor flex cable: passo 4, immagine 2 di 2
      • Lay the watch face down.
      • Carefully swing open the back cover by folding it to the opposite site of the created gap.
      • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Core Assembly Removal, Remove the back cover: passo 5, immagine 1 di 1
      • Remove the back cover.
      • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
      Chiedi a FixBot
      Aggiungi Commento
    1. Core Assembly Removal, Disconnect the hall sensor flex cable: passo 6, immagine 1 di 2 Core Assembly Removal, Disconnect the hall sensor flex cable: passo 6, immagine 2 di 2
      • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
      Chiedi a FixBot
      Aggiungi Commento
    2. Core Assembly Removal, Disconnect the display flex cable: passo 7, immagine 1 di 2 Core Assembly Removal, Disconnect the display flex cable: passo 7, immagine 2 di 2
      • Use a spudger to disconnect the display flex cable.
      Chiedi a FixBot
      Aggiungi Commento
    3. Core Assembly Removal, Disconnect the side buttons: passo 8, immagine 1 di 2 Core Assembly Removal, Disconnect the side buttons: passo 8, immagine 2 di 2
      • Use a spudger to disconnect the crown button flex cable.
      Chiedi a FixBot
      Aggiungi Commento
    4. Core Assembly Removal, Unscrew the motherboard: passo 9, immagine 1 di 1
      • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
      Chiedi a FixBot
      Aggiungi Commento
    5. Core Assembly Removal, Remove the motherboard: passo 10, immagine 1 di 3 Core Assembly Removal, Remove the motherboard: passo 10, immagine 2 di 3 Core Assembly Removal, Remove the motherboard: passo 10, immagine 3 di 3
      • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
      • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
      Chiedi a FixBot
      Aggiungi Commento
    1. Core Assembly Removal, Lift the core assembly: passo 11, immagine 1 di 3 Core Assembly Removal, Lift the core assembly: passo 11, immagine 2 di 3 Core Assembly Removal, Lift the core assembly: passo 11, immagine 3 di 3
      • Place the corner of the flat end of a spudger in the small opening of the barometric sensor, on the opposite side of the display connector.
      • Twist and tilt the spudger to lever the core assembly out of the metal housing.
      Chiedi a FixBot
      Aggiungi Commento
    2. Core Assembly Removal, Release the core assembly: passo 12, immagine 1 di 2 Core Assembly Removal, Release the core assembly: passo 12, immagine 2 di 2
      • Thread the display flex cable through the opening in the core assembly.
      Chiedi a FixBot
      Aggiungi Commento
    3. Core Assembly Removal, Remove the core assembly: passo 13, immagine 1 di 1
      • Remove the core assembly.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Altre 2 persone hanno completato questa guida.
Adriana Zwink
Membro da: 12/18/19
68.108 Reputazione
167 guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
65.879 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 47
Tutti i Tempi: 1,577
