Salta al contenuto principale
Coolpix S01 Zoom Trigger Replacement
angelica fitzgerald
angelica fitzgerald e 3 altri collaboratori
Ultimo aggiornamento il May 7, 2024
Nessuna stima
Moderato
Dettagli Mancanti
Introduzione
Vai al passo 1
Broken zoom trigger? No problem! If you own a Nikon Coolpix digital camera and are experiencing a jammed zoom trigger or a zoom trigger that just won't work, this guide will surely help.
Cosa ti serve
Strumenti
Mostra di più…
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: passo 1, immagine 1 di 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: passo 1, immagine 2 di 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: passo 1, immagine 3 di 3
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: passo 2, immagine 1 di 3 Coolpix S01 Zoom Trigger Replacement: passo 2, immagine 2 di 3 Coolpix S01 Zoom Trigger Replacement: passo 2, immagine 3 di 3
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: passo 3, immagine 1 di 2 Coolpix S01 Zoom Trigger Replacement: passo 3, immagine 2 di 2
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: passo 4, immagine 1 di 2 Coolpix S01 Zoom Trigger Replacement: passo 4, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 376
