Salta al contenuto principale
ClickN Kids Tablet Battery Replacement
Cosa ti serve
  1. ClickN Kids Tablet Battery Replacement, Battery: passo 1, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  2. ClickN Kids Tablet Battery Replacement: passo 2, immagine 1 di 1
    • Using the iFix it opening tool, pry battery apart from back side of tablet.
    • The battery is connected to the back side by a strong adhesive.
    • The battery may bend during this process.
    • Be careful not to allow the battery to bend any more than necessary. Battery acid leakage is possible.
    • Be careful not to damage the wires or the black tab attached to the battery.
    Chiedi a FixBot
    Aggiungi Commento
  3. ClickN Kids Tablet Battery Replacement: passo 3, immagine 1 di 3 ClickN Kids Tablet Battery Replacement: passo 3, immagine 2 di 3 ClickN Kids Tablet Battery Replacement: passo 3, immagine 3 di 3
    • Gently remove tape from the side of the battery connecting to wires and circuits.
    Chiedi a FixBot
    Aggiungi Commento
  4. ClickN Kids Tablet Battery Replacement: passo 4, immagine 1 di 3 ClickN Kids Tablet Battery Replacement: passo 4, immagine 2 di 3 ClickN Kids Tablet Battery Replacement: passo 4, immagine 3 di 3
    • Desolder wires connecting battery to motherboard, using contact points found on motherboard.
    • Have someone who is skilled in soldering to perform this step.
    • Be careful not to destroy the motherboard or other parts of device.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Baylor, Team 4-4, Williams Spring 2015 Membro di Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Membri
8 guide realizzate
3Commenti sulla guida
Como puedo conseguir el repuesto de mi tabletas epik
Reyshaliz - Rispondi Condividi
A little then moderate skill is necessary if you are somewhat mechanically inclined shouldn't be too problematic. But as far as this gentleman's directions and steps perform the task with no problems and tablet works now. Thank you Kevin Finney and three others my four-year-old daughter Hazel is happy again thanks to you.
Collins Hill
Great Smoky Mountains , TN.
Elivia Hill - Rispondi Condividi
I think these are great instructions for fixing this issue!
If you'd be interested in going a step further…I've been trying to find out how to safely remove the charge port! I know how to solder the replacement onto the board but I can't confirm the best way to detach the old port!?
My god daughter would appreciate another video! :)
JenBcute - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 5
Ultimi 30 giorni: 38
Tutti i Tempi: 5,257
