Salta al contenuto principale
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Anna Kihm
Anna Kihm e 3 altri collaboratori
Ultimo aggiornamento il 10 gen 2015
10 - 15 minuti
Facile
Foto Azione
Introduzione
Vai al passo 1
If the screen is cracked or not working it may be necessary to replace it. This guide will show how to conduct a screen replacement.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: passo 1, immagine 1 di 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: passo 2, immagine 1 di 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: passo 2, immagine 2 di 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: passo 3, immagine 1 di 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: passo 4, immagine 1 di 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: passo 4, immagine 2 di 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: passo 5, immagine 1 di 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: passo 6, immagine 1 di 1
    • The screen is located at the top of the device.
  7. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: passo 7, immagine 1 di 1
    • Carefully remove screen from device by lifting upward.
Conclusione
Anna Kihm
Membro da: 10/13/14
956 Reputazione
5 Guide realizzate
Clemson, Team 2-4, Benson Fall 2014 Membro di Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Membri
6 Guide realizzate
1Commento della guida
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,644
