Salta al contenuto principale
Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement
Bryce Colangelo
Bryce Colangelo e un altro collaboratore
Ultimo aggiornamento il July 22, 2023
1 minuto
Facile
Introduzione
Vai al passo 1
This is a guide for how to replace the eyepiece knob. Follow this guide for instructions on how to remove the eyepiece knob, repeating the steps for each side and then adding the new eyepiece knob.
  1. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement, Skin Cover: passo 1, immagine 1 di 2 Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement, Skin Cover: passo 1, immagine 2 di 2
    • Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
  2. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: passo 2, immagine 1 di 2 Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: passo 2, immagine 2 di 2
    • Start peeling the skin away from the center. Apply force as there is an adhesive substance that is binding the skin to the device. Continue peeling until skin cover slides off completely.
  3. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: passo 3, immagine 1 di 1
    • Repeat steps 1 and 2 for the other side.
  4. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement, Eyepiece Knob: passo 4, immagine 1 di 1
    • Twist the eyepiece knob counter-clockwise until it starts coming off.
  5. Celestron 71328 Nature DX 8x25 Eyepiece Knob Replacement: passo 5, immagine 1 di 1
    • Repeat Step 1 for the other side if necessary.
Conclusione
USF Tampa, Team S6-G6, Lacy Spring 2017 Membro di USF Tampa, Team S6-G6, Lacy Spring 2017
USFT-LACY-S17S6G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 640
