Salta al contenuto principale
Ceiling Fan Pull Chain Switch Replacement
Berkeli Alashov
Berkeli Alashov e 3 altri collaboratori
Ultimo aggiornamento il June 23, 2022
10 - 20 minuti
Moderato
Foto Azione
Introduzione
Vai al passo 1
This guide will show you how to replace a ceiling fan pull chain switch.
Ceiling fan pull chains can break in two different ways:
  1. Chain breaks somewhere in the middle, outside the fan housing
    • In this case, the chain can be fixed by adding an extension chain.
  2. Chain breaks inside the fan housing
    • The chain will not be visible from the outside, so the fan housing must be opened to replace the chain or the pull chain switch itself.
This is a guide for replacing the pull chain switch.
Warning: Following this guide may expose you to voltage. Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan to prevent injury.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: passo 1, immagine 1 di 2 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: passo 1, immagine 2 di 2
    • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
    • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
  2. Ceiling Fan Pull Chain Switch Replacement: passo 2, immagine 1 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 2, immagine 2 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 2, immagine 3 di 3
    • Caution: Let the bulbs cool off before you remove them.
    • Remove the bulbs from their sockets.
  3. Ceiling Fan Pull Chain Switch Replacement: passo 3, immagine 1 di 2 Ceiling Fan Pull Chain Switch Replacement: passo 3, immagine 2 di 2
    • Remove the screws around the base.
    • Remove the fan housing.
  4. Ceiling Fan Pull Chain Switch Replacement: passo 4, immagine 1 di 1
    • Pull the switch out of the fan housing, leaving the wires attached.
  5. Ceiling Fan Pull Chain Switch Replacement: passo 5, immagine 1 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 5, immagine 2 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 5, immagine 3 di 3
    • Cut the colored wires from the switch using a pair of wire cutters.
    • On some switch models, the wires can be detached by pulling.
  6. Ceiling Fan Pull Chain Switch Replacement: passo 6, immagine 1 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 6, immagine 2 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 6, immagine 3 di 3
    • Note the wire colors and the terminal they attach to on the old switch.
    • 1 - Red
    • 2 - Purple
    • 3 - Yellow
    • L - Black
  7. Ceiling Fan Pull Chain Switch Replacement: passo 7, immagine 1 di 1
    • Attach the colored wires to the new switch's respective terminals.
  8. Ceiling Fan Pull Chain Switch Replacement: passo 8, immagine 1 di 2 Ceiling Fan Pull Chain Switch Replacement: passo 8, immagine 2 di 2
    • Put back the switch in the hole in the fan housing from the inside.
    • Tighten up the screws on the outside.
  9. Ceiling Fan Pull Chain Switch Replacement: passo 9, immagine 1 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 9, immagine 2 di 3 Ceiling Fan Pull Chain Switch Replacement: passo 9, immagine 3 di 3
    • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
  10. Ceiling Fan Pull Chain Switch Replacement: passo 10, immagine 1 di 2 Ceiling Fan Pull Chain Switch Replacement: passo 10, immagine 2 di 2
    • Turn the power back on and test the switch to find if it is working or not.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 170
Tutti i Tempi: 13,680
