Casio CTK-501 LCD Screen Replacement
Introduzione
Vai al passo 1At some point during the use of your Casio CTK-501, you might encounter a time where the LCD screen starts to malfunction or in some cases just stop working. With this guide we will help you get to the screen, and show you how to replace it so that the screen can work like new.
For this repair you will need a total of two things, a #2 Phillips head screwdriver, and two pieces of tape. If you're not sure if you have the right tools or if you're not sure where to get them, the links to both the tape and screwdriver have been provided.
Before starting on this guide, check again to see if the screen is working or not, power it on and off a couple times, and make sure it's connected to a power source. If the problem still persists and the screen isn't working, you can continue with the guide, but check and be sure that the device is completely powered off before starting to take it apart.
Cosa ti serve
Flip the keyboard over so that the bottom is facing up.
Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
Completely unscrew and remove all six of the screws on the central circuit board.
Replace the LCD screen and tape it down to the top cover.
Altre 2 persone hanno completato questa guida.
3Commenti sulla guida
Hi. Would this screen work for CTK 481?
hi. I have the ctk 4300. i would like to know where i can get one.Binitintimo@gmail.com
