Canon Powershot SD790 IS LCD Screen Replacement
Introduzione
Vai al passo 1Use this guide to remove and replace a broken LCD screen for a Canon PowerShot SD790 IS camera.
The LCD screen is a monitor that allows you to view pictures you have taken. If your screen has black spots or blurred areas, visible scratches or crack lines, or there is a lack of touch sensitivity, this could mean your screen is defective or broken.
No special skills required to perform this repair. Make sure to power off the camera and remove it from the charger before beginning.
Cosa ti serve
Remove the two screws from the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws from the right side of the camera using a Phillips #00 screwdriver.
Remove the two screws from the bottom of the camera using a Phillips #00 screwdriver.
Using your fingers, manually open the USB cover, labeled as “A/V OUT DIGITAL.”
Gently pull the tab of the side cover, completely detaching the cover from the camera.
Altre 2 persone hanno completato questa guida.
