Salta al contenuto principale
Canon Powershot S200 Motherboard Replacement
Orlando Zuniga
Orlando Zuniga e 10 altri collaboratori
Ultimo aggiornamento il June 15, 2020
20 - 25 minuti
Moderato
Introduzione
Vai al passo 1
The motherboard is what contains and connects the principal components of the camera and controls all of its functions. If there is an electronic issue with your camera, for example if auto-focus is no longer functional, there is a high chance that there is an issue with the motherboard. This guide is moderately difficult and will take some time and patience but requires very few tools. It will walk you through all of the steps needed to disassemble the Canon Powershot S200 camera in order to take out the motherboard.
Cosa ti serve
Strumenti
  1. Canon Powershot S200 Motherboard Replacement, Battery: passo 1, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Motherboard Replacement: passo 2, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 2, immagine 2 di 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Motherboard Replacement: passo 3, immagine 1 di 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Motherboard Replacement, Motherboard: passo 4, immagine 1 di 1
    • Remove the lanyard.
  5. Canon Powershot S200 Motherboard Replacement: passo 5, immagine 1 di 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Motherboard Replacement: passo 6, immagine 1 di 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Motherboard Replacement: passo 7, immagine 1 di 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Motherboard Replacement: passo 8, immagine 1 di 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Motherboard Replacement: passo 9, immagine 1 di 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Motherboard Replacement: passo 10, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 10, immagine 2 di 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Motherboard Replacement: passo 11, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 11, immagine 2 di 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Motherboard Replacement: passo 13, immagine 1 di 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Motherboard Replacement: passo 15, immagine 1 di 2 Canon Powershot S200 Motherboard Replacement: passo 15, immagine 2 di 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Motherboard Replacement: passo 17, immagine 1 di 1
    • Remove the motherboard from the main frame of the camera body.
Conclusione
Orlando Zuniga
Membro da: 04/14/11
11 Reputazione
1 Guida realizzata
Cal Poly, Team 20-70, Walters Spring 2011 Membro di Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,933
