Salta al contenuto principale
Canon PowerShot SX160 IS Format Wheel Replacement
Jamie Secretan
Jamie Secretan e 2 altri collaboratori
Ultimo aggiornamento il June 22, 2015
15 - 30 minuti
Moderato
Fallo a Fettine
Introduzione
Vai al passo 1
This guide walks you through how to replace a format wheel on your Canon PowerShot SX160 IS by disassembling a portion of the camera to access the non operational piece.
Cosa ti serve
Strumenti
  1. Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: passo 1, immagine 1 di 2 Canon PowerShot SX160 IS Format Wheel Replacement, Format Wheel: passo 1, immagine 2 di 2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the back of the camera.
    • The screws are located directly above the LCD screen.
  2. Canon PowerShot SX160 IS Format Wheel Replacement: passo 2, immagine 1 di 2 Canon PowerShot SX160 IS Format Wheel Replacement: passo 2, immagine 2 di 2
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the side of the camera.
    • Use a #0 phillips screwdriver to unscrew the two black 4.8mm phillips head screws from the bottom of the camera.
  3. Canon PowerShot SX160 IS Format Wheel Replacement: passo 3, immagine 1 di 2 Canon PowerShot SX160 IS Format Wheel Replacement: passo 3, immagine 2 di 2
    • Use your hands to gently separate the back plate from the camera.
    • Slowly pull off the camera plate until it fully detaches from the camera.
  4. Canon PowerShot SX160 IS Format Wheel Replacement: passo 4, immagine 1 di 2 Canon PowerShot SX160 IS Format Wheel Replacement: passo 4, immagine 2 di 2
    • Use your hands to gently separate the front plate from the camera.
  5. Canon PowerShot SX160 IS Format Wheel Replacement: passo 5, immagine 1 di 1
    • Locate and replace the format wheel on the front panel of the camera.
Conclusione
Congratulations, you have successfully replaced your format wheel. To reassemble your device, follow these instructions in reverse order.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 19
Tutti i Tempi: 716
