Salta al contenuto principale
Canon PowerShot SD850 IS Function Set Button Replacement
iDeleted
iDeleted e 6 altri collaboratori
Ultimo aggiornamento il December 15, 2017
Nessuna stima
Moderato
Immagini Non Adeguate
Foto Azione
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This manual is for replacing the function/set button located on the back of the camera.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon PowerShot SD850 IS Function Set Button Replacement, Battery: passo 1, immagine 1 di 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: passo 1, immagine 2 di 3 Canon PowerShot SD850 IS Function Set Button Replacement, Battery: passo 1, immagine 3 di 3
    • Slide the light grey tab toward the edge of the camera using your fingernail.
    • Pull the light grey tab up to open the door.
    • These photos do not show the camera’s memory card or battery, which should be visible inside.
  2. Canon PowerShot SD850 IS Function Set Button Replacement: passo 2, immagine 1 di 2 Canon PowerShot SD850 IS Function Set Button Replacement: passo 2, immagine 2 di 2
    • Slide the small brown tab toward the edge of the camera using your fingernail.
    • Let go of the brown tab when the battery pops up.
    • Grab battery and pull straight up to remove from holder.
    • When inserting the battery, orient it so that the terminals connect.
  3. Canon PowerShot SD850 IS Function Set Button Replacement, Case: passo 3, immagine 1 di 2 Canon PowerShot SD850 IS Function Set Button Replacement, Case: passo 3, immagine 2 di 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  4. Canon PowerShot SD850 IS Function Set Button Replacement: passo 4, immagine 1 di 3 Canon PowerShot SD850 IS Function Set Button Replacement: passo 4, immagine 2 di 3 Canon PowerShot SD850 IS Function Set Button Replacement: passo 4, immagine 3 di 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  5. Canon PowerShot SD850 IS Function Set Button Replacement: passo 5, immagine 1 di 2 Canon PowerShot SD850 IS Function Set Button Replacement: passo 5, immagine 2 di 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  6. Canon PowerShot SD850 IS Function Set Button Replacement: passo 6, immagine 1 di 2 Canon PowerShot SD850 IS Function Set Button Replacement: passo 6, immagine 2 di 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  7. Canon PowerShot SD850 IS Function Set Button Replacement: passo 7, immagine 1 di 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  8. Canon PowerShot SD850 IS Function Set Button Replacement: passo 8, immagine 1 di 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  9. Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: passo 9, immagine 1 di 2 Canon PowerShot SD850 IS Function Set Button Replacement, Function Set Button: passo 9, immagine 2 di 2
    • Identify and remove the plastic function set button. Do this by gently prying up as indicated in the photo.
  10. Canon PowerShot SD850 IS Function Set Button Replacement: passo 10, immagine 1 di 1
    • Lift the function set button ribbon cable from the two guide pins.
  11. Canon PowerShot SD850 IS Function Set Button Replacement: passo 11, immagine 1 di 1
    • Remove the ribbon cable by lifting on the flat tab and pulling the ribbon cable from the connection.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,184
