Introduzione
The Canon PowerShot SD850 IS digital camera uses rechargeable batteries that you will occasionally have to remove. You can tell that your battery needs charging when the camera fails to turn on or displays a low battery indicator onscreen. Fortunately, you can easily get your camera running again. This guide explains how to remove or install the battery of your Canon PowerShot SD850 IS in two simple steps.
Slide the light grey tab toward the edge of the camera using your fingernail.
Pull the light grey tab up to open the door.
To reassemble your device, follow thee instructions in reverse order.
