Salta al contenuto principale
Canon PowerShot SD800 IS LCD Assembly Replacement
Jeremy Rabaino
Jeremy Rabaino e 5 altri collaboratori
Ultimo aggiornamento il July 30, 2014
10 - 15 minuti
Moderato
Guida In Evidenza
Introduzione
Vai al passo 1
Remove the back cover before removing LCD.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Canon PowerShot SD800 IS LCD Assembly Replacement, Back Cover: passo 1, immagine 1 di 1
    • Remove one 2.25mm screw on the bottom.
  2. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 2, immagine 1 di 1
    • Remove two 2.25mm screws on the right side looking from the front.
  3. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 3, immagine 1 di 1
    • Remove one 4.7mm screw on the side with the AV output.
  4. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 4, immagine 1 di 1
    • Pull off the back cover.
    • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
  5. Canon PowerShot SD800 IS LCD Assembly Replacement, LCD Assembly: passo 5, immagine 1 di 1
    • Remove 2 2.4mm screws on bottom.
  6. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 6, immagine 1 di 1
    • Follow the small data cable to where it connects to the camera.
    • Lift the back white portion to unlock the cable.
    • The cable should easily slide out.
    • The connector is very fragile. Use caution when lifting the lock.
  7. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 7, immagine 1 di 1
    • Gently lift LCD display off.
    • There will be two data cables still attached to the camera. Do not break them.
    • There may be a loose strip of metal along the inner side of the LCD display for a secure fit.
  8. Canon PowerShot SD800 IS LCD Assembly Replacement: passo 8, immagine 1 di 1
    • Follow the larger cable to where it connects to the camera.
    • Lift the front black portion of the connector to unlock the data cable.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 20-9, Maness Fall 2010 Membro di Cal Poly, Team 20-9, Maness Fall 2010
CPSU-MANESS-F10S20G9
5 Membri
8 Guide realizzate
1Commento della guida
where can I buy a replacement LCD screen for a SD800 IS
ALFRED - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 30
Tutti i Tempi: 2,354
