Salta al contenuto principale
Canon PowerShot SD400 LCD Replacement
Yi Huang Ke
Yi Huang Ke e 12 altri collaboratori
Ultimo aggiornamento il October 14, 2024
Nessuna stima
Moderato
Tagliatore di Passi
Attrezzi Non Corretti
Inconveniente Markup
Passi mancanti
Dettagli Mancanti
Introduzione
Vai al passo 1
This guide offers detailed, step-by-step instructions for replacing a faulty LCD screen on your Canon PowerShot SD400. The LCD, or liquid crystal display, serves as the camera's monitor for images, and it may require replacement if you notice cracks, discolored pixels, spots, blobs, flickering, or a complete loss of image signal. Before you get started, make sure to power off the camera and remove the battery.
Cosa ti serve
Strumenti
  1. Canon PowerShot SD400 LCD Replacement, Battery: passo 1, immagine 1 di 2 Canon PowerShot SD400 LCD Replacement, Battery: passo 1, immagine 2 di 2
    • Slide the battery cover open (indicated by the blue box).
  2. Canon PowerShot SD400 LCD Replacement: passo 2, immagine 1 di 1
    • Push in the orange clip (indicated by the blue box) to eject the battery.
  3. Canon PowerShot SD400 LCD Replacement: passo 3, immagine 1 di 1
    • Insert the charged battery back into the slot (indicated by the blue box).
    • Close the cover.
  4. Canon PowerShot SD400 LCD Replacement, LCD: passo 4, immagine 1 di 3 Canon PowerShot SD400 LCD Replacement, LCD: passo 4, immagine 2 di 3 Canon PowerShot SD400 LCD Replacement, LCD: passo 4, immagine 3 di 3
    • Locate these six screws that need to be removed to open the camera’s housing. These screws can be found on the bottom and both sides of the camera.
  5. Canon PowerShot SD400 LCD Replacement: passo 5, immagine 1 di 3 Canon PowerShot SD400 LCD Replacement: passo 5, immagine 2 di 3 Canon PowerShot SD400 LCD Replacement: passo 5, immagine 3 di 3
    • Using the screwdriver, carefully remove the exterior screws and place them in a safe location to avoid misplacing them.
  6. Canon PowerShot SD400 LCD Replacement: passo 6, immagine 1 di 2 Canon PowerShot SD400 LCD Replacement: passo 6, immagine 2 di 2
    • Locate the interior screw that is above the top right of the LCD screen.
    • Remove the screw using the screwdriver.
  7. Canon PowerShot SD400 LCD Replacement: passo 7, immagine 1 di 3 Canon PowerShot SD400 LCD Replacement: passo 7, immagine 2 di 3 Canon PowerShot SD400 LCD Replacement: passo 7, immagine 3 di 3
    • Locate the two clips on the left side of the LCD screen.
    • Carefully insert the tip of a flat-head screwdriver under the two clips of the LCD screen.
    • Slowly lift the screen using the flat-head screwdriver.
    • Potential for device damage Lift the screen gently to avoid any damage.
    Then what what to do next
    Keeneh Weah Cisco - Replica
Conclusione
Altre 2 persone hanno completato questa guida.
James Madison, Team 1-1, Allen Fall 2011 Membro di James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Membri
4 Guide realizzate
1Commento della guida
Do you carry a lcd screen for the Powershot sd400?
Jesus Licon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 3,365
