Salta al contenuto principale
Canon PowerShot SD200 Memory Card Replacement
James Loy
James Loy e 7 altri collaboratori
Ultimo aggiornamento il February 27, 2017
1 minuto
Molto facile
Introduzione
Vai al passo 1
The Canon PowerShot SD200 has an opening for a SD Memory Card. Removing the memory card might be necessary to obtain pictures from the camera. This guide will show how to easily remove the memory card.
  1. Canon PowerShot SD200 Memory Card Replacement, Memory Card: passo 1, immagine 1 di 3 Canon PowerShot SD200 Memory Card Replacement, Memory Card: passo 1, immagine 2 di 3 Canon PowerShot SD200 Memory Card Replacement, Memory Card: passo 1, immagine 3 di 3
    • Use your fingernail to slide the dark gray tab towards the edge of the camera.
    • Slide the light gray door away from the LCD screen and pull up to open the door.
    • The battery and the memory card slots should now be visible.
  2. Canon PowerShot SD200 Memory Card Replacement: passo 2, immagine 1 di 1
    • Press down on the memory card.
    • Memory card should pop out of place.
    • Pull the memory card straight out of the slot.
    • When putting the memory card back in, orient the memory card in the same direction when pulling out.
Conclusione
James Loy
Membro da: 10/06/10
103 Reputazione
7 Guide realizzate
Cal Poly, Team 5-12, Maness Fall 2010 Membro di Cal Poly, Team 5-12, Maness Fall 2010
CPSU-MANESS-F10S5G12
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,453
