Salta al contenuto principale
Canon PowerShot SD1000 Flash Unit Replacement
Cosa ti serve
  1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: passo 1, immagine 1 di 2 Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: passo 1, immagine 2 di 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Flash Unit Replacement: passo 2, immagine 1 di 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Flash Unit Replacement: passo 3, immagine 1 di 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Flash Unit Replacement: passo 4, immagine 1 di 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Flash Unit Replacement: passo 5, immagine 1 di 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Flash Unit Replacement, Front Case: passo 6, immagine 1 di 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Flash Unit Replacement: passo 7, immagine 1 di 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Flash Unit Replacement, LCD Screen: passo 8, immagine 1 di 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Flash Unit Replacement: passo 9, immagine 1 di 2 Canon PowerShot SD1000 Flash Unit Replacement: passo 9, immagine 2 di 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Flash Unit Replacement: passo 10, immagine 1 di 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Flash Unit Replacement: passo 11, immagine 1 di 2 Canon PowerShot SD1000 Flash Unit Replacement: passo 11, immagine 2 di 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Flash Unit Replacement: passo 12, immagine 1 di 3 Canon PowerShot SD1000 Flash Unit Replacement: passo 12, immagine 2 di 3 Canon PowerShot SD1000 Flash Unit Replacement: passo 12, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: passo 13, immagine 1 di 2 Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: passo 13, immagine 2 di 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Flash Unit Replacement: passo 14, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Flash Unit Replacement: passo 15, immagine 1 di 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Flash Unit Replacement: passo 16, immagine 1 di 2 Canon PowerShot SD1000 Flash Unit Replacement: passo 16, immagine 2 di 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
Conclusione
Cal Poly, Team 8-18, Maness Winter 2012 Membro di Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Membri
12 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,766
