Salta al contenuto principale
Canon PowerShot G16 Button Circuit Board Replacement
Jonathan Harger
Jonathan Harger e 9 altri collaboratori
Ultimo aggiornamento il December 5, 2024
15 - 20 minuti
Facile
Introduzione
Vai al passo 1
Please follow these steps to replace the button memory board.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon PowerShot G16 Button Circuit Board Replacement, Battery: passo 1, immagine 1 di 3 Canon PowerShot G16 Button Circuit Board Replacement, Battery: passo 1, immagine 2 di 3 Canon PowerShot G16 Button Circuit Board Replacement, Battery: passo 1, immagine 3 di 3
    • Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
    • Remove your finger and allow the flap to pop open.
  2. Canon PowerShot G16 Button Circuit Board Replacement: passo 2, immagine 1 di 3 Canon PowerShot G16 Button Circuit Board Replacement: passo 2, immagine 2 di 3 Canon PowerShot G16 Button Circuit Board Replacement: passo 2, immagine 3 di 3
    • Push the brown lever so that it pivots counterclockwise.
    • Grip and remove the battery.
    If I cannot open card/Batt. Open how??
    Jose Ocasio - Replica
  3. Canon PowerShot G16 Button Circuit Board Replacement, Button Circuit Board: passo 3, immagine 1 di 3 Canon PowerShot G16 Button Circuit Board Replacement, Button Circuit Board: passo 3, immagine 2 di 3 Canon PowerShot G16 Button Circuit Board Replacement, Button Circuit Board: passo 3, immagine 3 di 3
    • Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
  4. Canon PowerShot G16 Button Circuit Board Replacement: passo 4, immagine 1 di 1
    • Remove the four 3.3 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Canon PowerShot G16 Button Circuit Board Replacement: passo 5, immagine 1 di 1
    • Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
  6. Canon PowerShot G16 Button Circuit Board Replacement: passo 6, immagine 1 di 1
    • Remove the two 3.3 mm screws near the speaker using a Phillips #00 screwdriver.
  7. Canon PowerShot G16 Button Circuit Board Replacement: passo 7, immagine 1 di 1
    • Open the port cover by lifting up the tab with your finger and remove the 7.3 mm screw underneath the cover using a Phillips #00 screwdriver.
    • Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
  8. Canon PowerShot G16 Button Circuit Board Replacement: passo 8, immagine 1 di 2 Canon PowerShot G16 Button Circuit Board Replacement: passo 8, immagine 2 di 2
    • Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
  9. Canon PowerShot G16 Button Circuit Board Replacement: passo 9, immagine 1 di 1
    • Using your fingers, carefully pry the front cover off starting at the bottom right.
  10. Canon PowerShot G16 Button Circuit Board Replacement: passo 10, immagine 1 di 2 Canon PowerShot G16 Button Circuit Board Replacement: passo 10, immagine 2 di 2
    • Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
    • Lift away the port cover housing.
  11. Canon PowerShot G16 Button Circuit Board Replacement: passo 11, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Reorient the camera so that you are looking at the back.
    • Make sure to pull the connector straight down as pulling up may cause harm to the connector.
    • Unplug the button circuit board from the motherboard by unlocking the ZIF connector (gently lift the brown lock that keeps the cable in place).
    • Pull the connector downwards with the tweezers.
    This is not completely correct. In order to pull the connector down without force, the little grey tap on the top of the connectorbox has to be flipped up.
    This particular step cost me the connection to the button curcuit board. I would be grateful for an indication of where I can buy a replacement. Thanks.
    Martin Salamon - Replica
    You saved my connection. Thank you. iFixit... I'm somewhat disappointed these steps haven't been corrected.
    It's worth noting that I had no luck with tweezers when attempting to remove the ribbon cable. The correct procedure would be to carefully lift the plastic clip with an iFixit spudger and then continue to step 12. The ribbon cable will pull out gently without any other coercion.
    Phil Howard - Replica
    The clip is a red/terracotta colour, this should be lifted like a lid (the hinge is mounted in the grey housing). The connector should be pulled downward as described. This should definitely be corrected. Thanks for the comments to assist. I added this for extra clarity on the colours only.
    Jon Mayers - Replica
    just destroyed it!, thanks for nothing...
    karollus invincibullus - Replica
    Lool, just noticed on the pictures you destroyed your connector as well. Good for you for posting faulty guide.
  12. Canon PowerShot G16 Button Circuit Board Replacement: passo 12, immagine 1 di 1
    • Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
    • Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
  13. Canon PowerShot G16 Button Circuit Board Replacement: passo 13, immagine 1 di 1
    • Lift the button circuit board away from the camera.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team 70-6, Forte Winter 2016 Membro di Cal Poly, Team 70-6, Forte Winter 2016
CPSU-FORTE-W16S70G6
4 Membri
7 Guide realizzate
2Commenti sulla guida
Your instructions were so simple. Now my Canon G15 is like new. Thanks so much for the good step by step instructions. Feel so fixing things on my own.
mhkoo1 - Replica
where do i buy a button circuit board
u81ou812 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,049
