Introduzione
Is your Canon PowerShot A80’s LCD screen blurry, cracked, or failing to display images? This guide walks you through replacing the faulty screen so your camera can function like new. A broken LCD makes it tough to focus on your subjects or navigate settings.
Important: Before starting, turn off the camera and remove the battery to avoid electric shock or damage. If you're unsure whether the screen is the issue, visit our troubleshooting page for more help.
Cosa ti serve
Using a Phillips #00 screwdriver, remove the two 2.9 mm screws on the side of the LCD screen.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Altre 4 persone hanno completato questa guida.
