Salta al contenuto principale
Canon PowerShot A620 Shutter Button Replacement
Jaime Abraham
Jaime Abraham e 3 altri collaboratori
Ultimo aggiornamento il March 21, 2020
15 - 30 minuti
Moderato
Necessarie Immagini Migliori
Introduzione Migliore
Cosa ti serve
Strumenti
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: passo 1, immagine 1 di 3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: passo 1, immagine 2 di 3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: passo 1, immagine 3 di 3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: passo 2, immagine 1 di 1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: passo 3, immagine 1 di 1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 4, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 4, immagine 2 di 2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: passo 5, immagine 1 di 1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: passo 6, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Front Panel: passo 6, immagine 2 di 2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 7, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: passo 7, immagine 2 di 2
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: passo 8, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: passo 8, immagine 2 di 2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: passo 9, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Back Panel: passo 9, immagine 2 di 2
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: passo 10, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: passo 10, immagine 2 di 2
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: passo 11, immagine 1 di 1
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: passo 12, immagine 1 di 2 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: passo 12, immagine 2 di 2
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: passo 13, immagine 1 di 1
    • The trigger button will fall off once the screws have been removed.
Conclusione
Jaime Abraham
Membro da: 09/08/14
350 Reputazione
3 Guide realizzate
CSU Fullerton, Team 1-1, Bruce Fall 2014 Membro di CSU Fullerton, Team 1-1, Bruce Fall 2014
CSUF-BRUCE-F14S1G1
3 Membri
6 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,485
