Salta al contenuto principale
Canon PowerShot A2500 LCD Display Replacement
Victoria Winters
Victoria Winters e 4 altri collaboratori
Ultimo aggiornamento il 6 mar 2020
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
The LCD screen will be removed and replaced in order to solve an issue with the LCD screen displays operation such as a deep scratch or crack. The LCD is an alternative display that can be used rather than looking through the camera itself.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: passo 1, immagine 1 di 2 Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: passo 1, immagine 2 di 2
    • Remove the knot holding the wrist lanyard onto the camera
  2. Canon PowerShot A2500 LCD Display Replacement: passo 2, immagine 1 di 1
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
  3. Canon PowerShot A2500 LCD Display Replacement: passo 3, immagine 1 di 3 Canon PowerShot A2500 LCD Display Replacement: passo 3, immagine 2 di 3 Canon PowerShot A2500 LCD Display Replacement: passo 3, immagine 3 di 3
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
  4. Canon PowerShot A2500 LCD Display Replacement: passo 4, immagine 1 di 3 Canon PowerShot A2500 LCD Display Replacement: passo 4, immagine 2 di 3 Canon PowerShot A2500 LCD Display Replacement: passo 4, immagine 3 di 3
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
  5. Canon PowerShot A2500 LCD Display Replacement, Buttons: passo 5, immagine 1 di 1
    • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
    • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
  6. Canon PowerShot A2500 LCD Display Replacement: passo 6, immagine 1 di 2 Canon PowerShot A2500 LCD Display Replacement: passo 6, immagine 2 di 2
    • Pull the two clips off located near the power button
    • The clips are easily broken, use care while disconnecting these clips.
  7. Canon PowerShot A2500 LCD Display Replacement: passo 7, immagine 1 di 3 Canon PowerShot A2500 LCD Display Replacement: passo 7, immagine 2 di 3 Canon PowerShot A2500 LCD Display Replacement: passo 7, immagine 3 di 3
    • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
    • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
    I feel that this guide is missing a step. The third picture shows the plate behind the buttons lifted off, but not how this is done. It appears to be held in place by a screw on the top of the camera that’s beneath the circuitry that I can’t find mentioned in the guide.
    Shannon Hamilton - Replica
    That is certainly true as I had to find out after many tries! Jack
    Jack Banks - Replica
  8. Canon PowerShot A2500 LCD Display Replacement, LCD Display: passo 8, immagine 1 di 1
    • Lift the tab at the end of the ribbon
    • Disconnect the ribbon from the circuitboard
Conclusione
1Commento della guida
There seams to be a step missing on step 6 . As there is a screw that has to be removed covered to the left of button on top of camera.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 37
Tutti i Tempi: 1,444
