Canon PowerShot A2500 LCD Display Replacement
Introduzione
Vai al passo 1The LCD screen will be removed and replaced in order to solve an issue with the LCD screen displays operation such as a deep scratch or crack. The LCD is an alternative display that can be used rather than looking through the camera itself.
Cosa ti serve
Remove the knot holding the wrist lanyard onto the camera
Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
Lift the tab at the end of the ribbon
Disconnect the ribbon from the circuitboard
1Commento della guida
There seams to be a step missing on step 6 . As there is a screw that has to be removed covered to the left of button on top of camera.
