Salta al contenuto principale
Canon EOS Rebel XTi Front Cover Replacement
Nicholas Abate
Nicholas Abate e 3 altri collaboratori
Ultimo aggiornamento il January 3, 2025
15 minuti
Moderato
Necessarie Più Immagini
Introduzione
Vai al passo 1
Removing the front portion of the casing is necessary to perform maintenance or replace parts on specific components on the front of the camera. In order to remove the front casing, the back will have to be removed first.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon EOS Rebel XTi Front Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Front Cover Replacement: passo 2, immagine 1 di 1
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Front Cover Replacement: passo 3, immagine 1 di 1
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Front Cover Replacement, Memory Card: passo 4, immagine 1 di 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Front Cover Replacement: passo 5, immagine 1 di 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Front Cover Replacement: passo 6, immagine 1 di 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Front Cover Replacement, Back Cover: passo 7, immagine 1 di 1
    • Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
  8. Canon EOS Rebel XTi Front Cover Replacement: passo 8, immagine 1 di 2 Canon EOS Rebel XTi Front Cover Replacement: passo 8, immagine 2 di 2
    • Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
  9. Canon EOS Rebel XTi Front Cover Replacement: passo 9, immagine 1 di 1
    • Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
  10. Canon EOS Rebel XTi Front Cover Replacement: passo 10, immagine 1 di 1
    • Remove the following screws located in the memory card slot:
    • Two M3x2mm JIS #000 screws
  11. Canon EOS Rebel XTi Front Cover Replacement: passo 11, immagine 1 di 1
    • Gently pry off the back casing.
    • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
    • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
    • Gently pull the ribbon cable out of the connector.
  12. Canon EOS Rebel XTi Front Cover Replacement, Front Cover: passo 12, immagine 1 di 1
    • Remove the following screws from the bottom of the camera:
    • Two M3x4.5mm JIS #000 screws
    • One M3x3mm JIS #000 screw
  13. Canon EOS Rebel XTi Front Cover Replacement: passo 13, immagine 1 di 1
    • Remove the following screws from the front of the camera:
    • Two M3x6mm JIS #000 screws
  14. Canon EOS Rebel XTi Front Cover Replacement: passo 14, immagine 1 di 1
    • Gently pry off the front casing.
    • There are no ribbon cables to remove for this portion of the disassembly.
Conclusione
USF Tampa, Team 8-6, Eyestone Fall 2015 Membro di USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,585
