Introduzione
If the flash of your Canon Rebel T6i (also known as model EOS 750D) is malfunctioning — not producing any light, or not triggering when taking a picture — use this guide to remove and replace the entire Flash Assembly.
Make sure to check the flash settings on your camera and confirm that the Flash Assembly is faulty. The camera flash should trigger when the camera mode is set to Automatic (A+) and the scene you are photographing is very dark.
Before beginning, remove the battery from your camera and disconnect from from any external power source.
Strumenti
Parti
Nessuna parte specificata.
Remove all visible exterior screws:
Two 6.84 mm J000 screws on the right side
Six 5.33 mm J000 screws
Two 5.33 mm J000 screws on either side of the viewfinder
To disconnect the white wire, pinch the wire casing and pull directly out from the camera. It will take a very small amount of elbow grease. However, do not force or pry it.
To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
Once removed, set the back in a safe place.
To remove the Ribbon connectors that have a locking mechanism, identify the flap on the ribbon connector. Use either needle nose tweezers, or a plastic wedge to flip the small flap to the "up" position.
Once the flap is up, use the plastic spudger to pull the ribbon connector out of the connection using the hole in the center of the ribbon.
Remove the button cell battery from the motherboard.
Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
Go ahead and disconnect all of the ribbon connectors along the top that you can get to. Don't worry about the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
Altre 2 persone hanno completato questa guida.
