Salta al contenuto principale
Canon EOS 60D Left-Side Port Cover Replacement
Eric D
Eric D e 2 altri collaboratori
Ultimo aggiornamento il February 1, 2020
5 - 10 minuti
Facile
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This will allow you access to the ports, or if you need to replace the dust cover, will allow you to do that.
Cosa ti serve
Strumenti
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Canon EOS 60D Left-Side Port Cover Replacement, Rubber grips: passo 1, immagine 1 di 1
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
  2. Canon EOS 60D Left-Side Port Cover Replacement, Left-Side Port Cover: passo 2, immagine 1 di 1
    • Remove 3 screws
    • Remove the small Screw under the Flip cover too
  3. Canon EOS 60D Left-Side Port Cover Replacement: passo 4, immagine 1 di 1
    • Using a Spudger, fingernail, or other thin plastic tool to wedge the panel off of the camera
    • Start at the camera's front. Pulling on the rubber av-cover may be enough to get it to move off the body
    • Only pull about 1/4" (3-5mm). There is a tab that will need to slide out
  4. Canon EOS 60D Left-Side Port Cover Replacement: passo 5, immagine 1 di 1
    • Slide the rear part of the cover out.
  5. Canon EOS 60D Left-Side Port Cover Replacement: passo 6, immagine 1 di 2 Canon EOS 60D Left-Side Port Cover Replacement: passo 6, immagine 2 di 2
    • At this point, the only thing holding on is the dust-cover is hooked onto the front panel
    • Slide down to remove without damaging the cover. (see photo with cover removed)
    • You can see how the cover, and side piece fit together in the second image.
Conclusione
Altre 8 persone hanno completato questa guida.
Eric D
Membro da: 11/13/12
1.362 Reputazione
5 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 48
Tutti i Tempi: 7,485
