Salta al contenuto principale
Canon EOS 30 LCD Screen Replacement
Sterling Vinson
Sterling Vinson e 4 altri collaboratori
Ultimo aggiornamento il 21 feb 2020
15 minuti
Moderato
Immagini Non Adeguate
Introduzione
Vai al passo 1
This guide will show you how to access, remove, and replace the LCD screen. The process is safe and uncomplicated.
Cosa ti serve
Strumenti
Mostra di più…
  1. Canon EOS 30 LCD Screen Replacement, Front Panel: passo 1, immagine 1 di 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Remove the front panel by lifting it away from the camera's body.
    I need a video tutorial
    Abdullah dicky S - Replica
  5. Canon EOS 30 LCD Screen Replacement, Top Panel: passo 5, immagine 1 di 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 LCD Screen Replacement: passo 8, immagine 1 di 2 Canon EOS 30 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 LCD Screen Replacement, LCD Screen: passo 9, immagine 1 di 1
    • To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
    • The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
  10. Canon EOS 30 LCD Screen Replacement: passo 10, immagine 1 di 1
    • Lift LCD screen out of mount.
    Thanks a lot this is the perfect step by step instructionsfor me to fix my camera!!!
    Brian Dale Whitaker - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 8-8, Regan Spring 2011 Membro di Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Membri
22 Guide realizzate
2Commenti sulla guida
Thank's , your tutorial nice ... gracias
fajar - Replica
Where do you find replacement lcd screen if the one on the camera is cracked?
Jasmine - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,486
