Salta al contenuto principale
Introduzione
Vai al passo 1
Canary is not so easy to disassemble. But fiddle with the rubber foot until it pops off, and you're on your way...
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo Video Camera, usa il nostro manuale di assistenza.
  1. Canary  Connect (Home Internet Security Camera), Cracking Open the Case: passo 1, immagine 1 di 2 Canary  Connect (Home Internet Security Camera), Cracking Open the Case: passo 1, immagine 2 di 2
    • The key to cracking open Canary is in the base. First pop off the rubber foot, and remove four screws.
    • Canary uses multiple screw types. If you ever hope to get it back together, consider a screw management system (here plastic bags for each section of the disassembly).
    • Once you get the base off, you'll need to peel off the front plate (held on with double sticky tape).
  2. Canary  Connect (Home Internet Security Camera), Dissecting the Base: passo 2, immagine 1 di 3 Canary  Connect (Home Internet Security Camera), Dissecting the Base: passo 2, immagine 2 di 3 Canary  Connect (Home Internet Security Camera), Dissecting the Base: passo 2, immagine 3 di 3
    • The base does not do all that much. It holds Ethernet, audio jack, and USB power plugs, along with a steel plate for heft.
    • Note the attention to detail: there's a second PCB board for no apparent purpose other than making the audio jack line up with the USB jack. That's obsession!
    • The little chimney is, in fact, a chimney. The idea is that hot air from the electronics rises, drawing room air. This is an older approach (see grated US patent http://patents.justia.com/patent/6347747 ).
  3. Canary  Connect (Home Internet Security Camera), Heat Sinks: passo 3, immagine 1 di 3 Canary  Connect (Home Internet Security Camera), Heat Sinks: passo 3, immagine 2 di 3 Canary  Connect (Home Internet Security Camera), Heat Sinks: passo 3, immagine 3 di 3
    • The inside is dominated by a aluminum plate with dimples for the Ambarella A5S CPU and the back of the image sensor. The heat sink presses against the outer case, through a squishy thermal interface material (TIM).
    • The huge round thing is a buzzer. The round PCB board hosts the 2.4Ghz WiFi and bluetooth antennas (there is no 5Ghz).
    • The infrared LED board sports a plastic frame to aim each LED separately.
  4. Canary  Connect (Home Internet Security Camera), What's Behind the Lens?: passo 4, immagine 1 di 2 Canary  Connect (Home Internet Security Camera), What's Behind the Lens?: passo 4, immagine 2 di 2
    • Canary achieves its flat lens front with an extra sheet of glass that's not optically active. Buried inside is a conventionally shaped M12 security lens.
    • A switchable IR blocking filter is included for day/night mode. This blocks IR light during the day, but switches to be transparent at night.
    • The lens holder is unremarkable. Components are placed within the light chamber to allow the back to support the heat sink.
    • Note the empty holes for... some sort of sensor, not stuffed. Maybe air quality?
    • That's it. I hope you've enjoyed this tour into the insides of Canary.
Bryce Nesbitt
Membro da: 11/30/14
1.206 Reputazione
8 Guide realizzate
3Commenti sulla guida
Hi there! What do they use measure air quality? In fact what is air quality for Canary - CO2 or something else?
Gary - Replica
Would like to know WiFi module model? Artheros?
Chihwei Lu - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 6,368
