Salta al contenuto principale
Brother CS6000i Thread Cutter Replacement
Ava Martinez
Ava Martinez e 2 altri collaboratori
Ultimo aggiornamento il December 31, 2024
55 secondi - 6 minuti
Molto facile
Introduzione
Vai al passo 1
This guide will be showing you how to remove and replace the thread cutter on a Brother CS6000i sewing machine. The thread cutter is a handy feature that allows the user to safely and easily cut the excess thread from the machine and workpiece. Some symptoms related to a faulty thread cutter are the thread not cutting when attempting to use the cutter (dull blade) or the thread cutter being overly exposed and no longer safe due to a broken blade enclosure.
Cosa ti serve
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Brother CS6000i Thread Cutter Replacement, Thread Cutter: passo 1, immagine 1 di 2 Brother CS6000i Thread Cutter Replacement, Thread Cutter: passo 1, immagine 2 di 2
    • Take off the the white cover on the front left side.
  2. Brother CS6000i Thread Cutter Replacement: passo 2, immagine 1 di 3 Brother CS6000i Thread Cutter Replacement: passo 2, immagine 2 di 3 Brother CS6000i Thread Cutter Replacement: passo 2, immagine 3 di 3
    • Remove the 8 mm Phillips #2 screw securing the thread cutter to the housing.
Conclusione
Ava Martinez
Membro da: 10/31/24
433 Reputazione
4 Guide realizzate
Cuesta, Team 20-1, Krynen Fall 2024 Membro di Cuesta, Team 20-1, Krynen Fall 2024
CUESTA-KRYNEN-F24S20G1
5 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 25
Tutti i Tempi: 81
