Salta al contenuto principale
Bottom Plate Removal
Sam Gustafson
Sam Gustafson e un altro collaboratore
Ultimo aggiornamento il February 18, 2025
20 minuti
Facile
Guida fornita dalla comunità
Cosa ti serve
Strumenti
  1. Bottom Plate Removal, Remove back cover: passo 1, immagine 1 di 1
    • Push down on the screw to depress the spring loaded hinge and release the door.
  2. Bottom Plate Removal, Remove bottom cover: passo 2, immagine 1 di 1
    • Remove six 5.3 mm #00 screws.
    • Remove one 3.4 mm #00 screw.
    • The short screw has a machine thread and screws into the plate underneath. The rest screw into the plastic body.
  3. Bottom Plate Removal, Remove left front cover: passo 3, immagine 1 di 1
    • Remove three 5.3 mm #00 screws (the bottom-most screw is not always present).
    • Remove one 7.3 mm #00 screw.
    • Remove the remote trigger cover.
  4. Bottom Plate Removal, Remove front cover: passo 4, immagine 1 di 2 Bottom Plate Removal, Remove front cover: passo 4, immagine 2 di 2
    • Remove two 5.3 mm #00 screw.
    • Gently lift up on the flash housing to help remove the cover if necessary.
  5. Bottom Plate Removal, Remove right front cover: passo 5, immagine 1 di 1
    • Remove two 3.9 mm #00 screws.
  6. Bottom Plate Removal, Prepare bottom plate: passo 6, immagine 1 di 2 Bottom Plate Removal, Prepare bottom plate: passo 6, immagine 2 di 2
    • Remove two 3.4 mm #00 screws. Remove the plate holding the contacts in place.
    • Peel tape from the plate. Leave the tape attached to the flex circuit.
    • Remove the flex circuits from their retaining studs.
  7. Bottom Plate Removal, Remove bottom plate: passo 7, immagine 1 di 2 Bottom Plate Removal, Remove bottom plate: passo 7, immagine 2 di 2
    • Remove one 3.3 mm #0 countersunk screw.
    • Remove one 3.9 mm #0 shoulder screw.
    • Remove four 3.3 mm #00 screws.
    • Pull a little slack through the housing on this flex cable.
    • Pop the plate off its posts, rotate slightly clockwise and pull gently through the loosened flex cable.
    • To the camera tech that left me a happy little note...I see you.
  8. Bottom Plate Removal, Remove transport gears: passo 8, immagine 1 di 2 Bottom Plate Removal, Remove transport gears: passo 8, immagine 2 di 2
    • It's best to remove these parts now so they don't fall out later on in the repair.
Conclusione
Sam Gustafson
Membro da: 09/01/22
7.682 Reputazione
42 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 22
Tutti i Tempi: 325
