Salta al contenuto principale
Bose QuietComfort 35 Earpad Replacement
Johnson Ou
Johnson Ou e 3 altri collaboratori
Ultimo aggiornamento il May 17, 2024
1 ora
Moderato
Introduzione
Vai al passo 1
With time and regular usage, damage from wear and tear is inevitable for over-ear headphone earpieces. Although Bose is known for long-lasting technology, their ear pads are known to peel after a short period of time. Constantly replacing them with low quality third-party ear pads or replacing them through Bose can be costly and wasteful. Through this repair, you can create custom long-lasting ear pads.
  1. Bose QuietComfort 35 Earpad Replacement, Earpad: passo 1, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement, Earpad: passo 1, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement, Earpad: passo 1, immagine 3 di 3
    • Reach a thumb under the damaged foam earpad and pull to remove from headphones.
  2. Bose QuietComfort 35 Earpad Replacement: passo 2, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 2, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 2, immagine 3 di 3
    • Locate the plastic oval ring attached to the foam ear pad.
    • Gently pull apart the plastic ring and leather fabric until separated.
  3. Bose QuietComfort 35 Earpad Replacement: passo 3, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 3, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 3, immagine 3 di 3
    • Rip the leather exterior until green foam is visible.
    • Remove green foam.
    • Dispose of damaged leather.
  4. Bose QuietComfort 35 Earpad Replacement: passo 4, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 4, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 4, immagine 3 di 3
    • Print the linked pattern.
    • Cut out the pattern using the solid black lines.
    • Trace the pattern onto the new leather.
  5. Bose QuietComfort 35 Earpad Replacement: passo 5, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 5, immagine 2 di 2
    • Cut out the leather following the traced lines.
  6. Bose QuietComfort 35 Earpad Replacement: passo 6, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 6, immagine 2 di 2
    • Using the pattern as a guide, mark holes on the smaller donut with a pencil
    • Punch holes with the leather punch tool
  7. Bose QuietComfort 35 Earpad Replacement: passo 7, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 7, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 7, immagine 3 di 3
    • Align the smaller donut on top of the larger donut
    • Make sure the leather right sides (the side of the leather you want to show) are facing each other
    • Using a thread and a needle, sew the two donuts together at the center of the donut using a whip stitch
  8. Bose QuietComfort 35 Earpad Replacement: passo 8, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 8, immagine 2 di 2
    • Turn the donut inside out
    • Make sure the leather right sides (the side of the leather you want to show) are facing away from each other
  9. Bose QuietComfort 35 Earpad Replacement: passo 9, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 9, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 9, immagine 3 di 3
    • Buff the outer edge of the small donut with a nail file
    • Glue the outer edge of the small donut with fabric glue
    • Leave the glue to dry for 5 minutes
  10. Bose QuietComfort 35 Earpad Replacement: passo 10, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 10, immagine 2 di 2
    • Buff the inner edge of the plastic ring
    • Glue the inner edge of the plastic ring
  11. Bose QuietComfort 35 Earpad Replacement: passo 11, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 11, immagine 2 di 2
    • Attach the plastic ring (glue side down) to the smaller donut
    • Leave to dry for 20 minutes
  12. Bose QuietComfort 35 Earpad Replacement: passo 12, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 12, immagine 2 di 2
    • Slide the leather ring through the cushion, leaving the plastic ring on the other side
  13. Bose QuietComfort 35 Earpad Replacement: passo 13, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 13, immagine 2 di 2
    • Apply glue to the edges of the leather donut
    • Put an object in between the donut for a better drying process
    • Leave to dry for 5 minutes
  14. Bose QuietComfort 35 Earpad Replacement: passo 14, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 14, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 14, immagine 3 di 3
    • Fold the leather down to the plastic ring, wrapping around the cushion ring
    • Straighten out the creases in the leather ring
  15. Bose QuietComfort 35 Earpad Replacement: passo 15, immagine 1 di 2 Bose QuietComfort 35 Earpad Replacement: passo 15, immagine 2 di 2
    • Use a paper clip to hold the pieces in place while letting glue dry
  16. Bose QuietComfort 35 Earpad Replacement: passo 16, immagine 1 di 3 Bose QuietComfort 35 Earpad Replacement: passo 16, immagine 2 di 3 Bose QuietComfort 35 Earpad Replacement: passo 16, immagine 3 di 3
    • Attach the leather earpads back onto the headphone
    • Apply light pressure to secure the earpads into place
Conclusione
Altre 2 persone hanno completato questa guida.
Documenti Allegati
Johnson Ou
Membro da: 02/01/24
298 Reputazione
1 Guida realizzata
UC Davis, Team 4-2, Andersen Winter 2024 Membro di UC Davis, Team 4-2, Andersen Winter 2024
UCD-ANDERSEN-W24S4G2
3 Membri
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 226
