Boosted Board 1st Generation Belts Replacement
Introduzione
Vai al passo 1This guide will show you how to remove and replace the belts on your board. The rear motor is load with springs, so be carful and pay close attention to the steps when taking the board apart. If your belt is broken, you will need to buy a new one through Boosted. Happy fixing!
Cosa ti serve
Strumenti
Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
Altre 4 persone hanno completato questa guida.
