Salta al contenuto principale
Blu Grand M2  Power Button Replacement
Alan Rodriguez
Alan Rodriguez e 9 altri collaboratori
Ultimo aggiornamento il 25 gen 2022
1 - 3 minuti
Facile
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
If your BLU Grand M2 phone is not responding when you are pressing the power button, you may need a power button replacement. This guide has been made to help you install your power button on your own. It will show you how to remove the screws, remove the back panel, and detach the power button.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Blu Grand M2  Power Button Replacement, Power Button: passo 1, immagine 1 di 1
    • Using a T2 Torx Screwdriver, remove the two screws from the bottom edge of the phone.
  2. Blu Grand M2  Power Button Replacement: passo 2, immagine 1 di 2 Blu Grand M2  Power Button Replacement: passo 2, immagine 2 di 2
    • Apply the suction tool to the back panel near the bottom edge.
    • Carefully slide the device pick between the back panel and bottom edge.
    • Insert the opening tool into the gap created by the device pick.
    • While holding the suction tool, use the opening tool to gently pry the back panel off.
    • Be Cautious to not damage the phone display and or the inside components while using the pry tool and suction tool.
  3. Blu Grand M2  Power Button Replacement: passo 3, immagine 1 di 1
    • Take the end of the opening tool and push the old power button out of its socket.
    • Remove the old power button.
  4. Blu Grand M2  Power Button Replacement: passo 4, immagine 1 di 1
    • Place the new BLU Grand M2 power button in the socket.
Conclusione
Gateway, Team S1-G3, Luster Fall 2018 Membro di Gateway, Team S1-G3, Luster Fall 2018
GCC-LUSTER-F18S1G3
4 Membri
4 Guide realizzate
1Commento della guida
Don’t forget to remove the SIM card
Jonathan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 401
